HB-25 Controller and Motor Wheel Kit...HELP!
Hello Everybody:
This is my first attempt at a·Parallax·robot and my first post. so go easy on me, please.
I am so new to this stuff, that I am still wet behind the ears! I've done the book 'What's a Microcontrller?' and I understood it pretty well and enjoyed the projects, but now I am stuck and sure you could some of your help.
I purchased the HB-25 and Mortor Wheel Kit and I am only going to use one motor on my project, for now anyway, and I'm not sure how to wire this thing up with regards to the Board of Education. It does not seem to be the same as the servo excercises and I dont want to cook anything. I've got it all assembled (one motor, the left one) and I have downloaded and programmed the BS2 with the sample test code, but again I'm just not sure how to wire it up. Black is Vss, Is Red Vdd? because it was Vin for the servo and i dont think I want 9v going to the circuit!
Does P15 go to white?
Any help such as a verbal or link to a diagram would be great!
Thank you,
EEwanabe
Does P15 go to white? Any help such as a verbal or link to a diagram would be great!
Thank you,
EEwanabe
http://www.parallax.com/Portals/0/Downloads/docs/prod/motors/27971-MotorMount-v1.2.pdf
Make sure that the jumper for the servo socket is set to Vdd.
Dave
Dave Andreae
Parallax Tech Support·
Thanks for the advice! I tried both, socket 15 and P15 but no luck. when the system is powered up the motor does have a dynamic brake effect (hard to turn wheel) and the cooling fan changes pitch if you try to turn the wheel.
Any more suggestions?
Dave
Dave Andreae
Thanks a lot for your help!
