GlobalVariable Error
Just tried to compile The GlobalVariable.
[noparse][[/noparse]Java Error] GlobalVariable.java (10):
Syntax } expected instead of this token.
Cheers.
Cheers.
Compiles fine.
This is the 3rd time you get errors compiling the examples.
So obviously the IDE installation is located on a bad spot
of·your harddisk.
You'd better reinstall IDE v2.0.3 but first rename
the current Javelin IDE folder to something else.
That way the new installation can use its default name
and it won't use the harddisk space occupied
by the current installation (which obviously is bad).
regards peter
