GlobalVariable Error — Parallax Forums
HeroHero Posts: 24
edited 2008-12-13 15:12 in General Discussion
Just tried to compile The GlobalVariable.
[noparse][[/noparse]Java Error] GlobalVariable.java (10):
Syntax } expected instead of this token.
Cheers.
  • Peter VerkaikPeter Verkaik Posts: 3,956
    Attached is my copy of that file.
    Compiles fine.
    This is the 3rd time you get errors compiling the examples.
    So obviously the IDE installation is located on a bad spot
    of·your harddisk.
    You'd better reinstall IDE v2.0.3 but first rename
    the current Javelin IDE folder to something else.
    That way the new installation can use its default name
    and it won't use the harddisk space occupied
    by the current installation (which obviously is bad).
    regards peter
