Propeller Dev Board - Strange failure mode.
Hugh
My pro dev board has been successfully processing GPS / IMU / Magnetometer / R/C transmitter data and displaying it on a VGA monitor for a while now. However, I started it today and no joy...
Any VGA monitor plugged into the board causes the power-supply LED to go out (i.e., some sort of short?) and the surface mount LED's don't light under any circumstances.
Bit of a dissappointment - can these boards be 'over worked'?(Surely not) I guess that they are not repairable either...
Hugh - the thinking woman's Geoffrey Pyke.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon
Does the board seem to work otherwise (if there's no VGA monitor plugged in)? Can you download a simple program to the Propeller that just blinks an LED? Does that work?
Yes, a simple LED-blinking program works OK (blinking P16 - P23, the same IO as the VGA connector).
I'll get in touch with Parallax.
Hugh
