Using PCI graphics card with propeller?
Has anyone messed with connecting the propeller to a standard pci graphics card for better graphics output? Is it feasable to do this or is this madness just to speak of it?
Jason
Jason
I'm not familiar with the PCI-Bus. I guess which means I don't kow exactly
but simply from the number of Pins a PCI-slot has and the speedrequirements
I guess it will be much easier to use a micro-PC-motherboard than a Propeller
with a graphic-card. For parallel reaction on different sensors it still might be useful
to use a propeller and send graphical data across a serial connection with 115200 Baud to the micro-PC
or to use two Propeller-Chips. One simply for 1024X768 Graphics and the other prop for the rest.
best regards
Stefan
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
-Brian
Leon
Biggest trick here might be locating working cards. [noparse]:)[/noparse]
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
