Using PCI graphics card with propeller? — Parallax Forums
sccoupesccoupe Posts: 118
edited 2008-12-16 02:59 in Propeller 1
Has anyone messed with connecting the propeller to a standard pci graphics card for better graphics output? Is it feasable to do this or is this madness just to speak of it?
Jason
    edited 2008-12-09 21:02
    Hello sccoupe,
    I'm not familiar with the PCI-Bus. I guess which means I don't kow exactly
    but simply from the number of Pins a PCI-slot has and the speedrequirements
    I guess it will be much easier to use a micro-PC-motherboard than a Propeller
    with a graphic-card. For parallel reaction on different sensors it still might be useful
    to use a propeller and send graphical data across a serial connection with 115200 Baud to the micro-PC
    or to use two Propeller-Chips. One simply for 1024X768 Graphics and the other prop for the rest.
    best regards
    Stefan
  • LeonLeon Posts: 7,620
    edited 2008-12-10 07:56
    PCI is rather tricky - it's fast and the PCB tracks need to be the same length. FPGAs are often used for interfaces to plug into a PC. I wouldn't bother.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • GameHackerGameHacker Posts: 15
    edited 2008-12-10 13:33
    If not PCI, what about ISA?· There must be some basic text commands that are common to all cards in order to show the BIOS startup.· I have event seen some logos using graphics.· I realise anything 3D would probably depend on the card.
    -Brian
    edited 2008-12-10 15:35
    ISA would be easy. I remember seeing 8-bit MCUs interfaced to ISA cards.
    Leon
  • Capt. QuirkCapt. Quirk Posts: 872
    edited 2008-12-16 02:17
    This example might help, but it was·for the sx 28
    isa.zip 10.1K
    edited 2008-12-16 02:46
    Leon said...
    Leon
    Biggest trick here might be locating working cards. [noparse]:)[/noparse]
    OBC
    New to the Propeller?
    Getting started with a Propeller Protoboard?
    Check out: Introduction to the Proboard & Propeller Cookbook 1.4
    Got an SD card connected? - PropDOS
    Depending on what you want to accomplish it may be easier to use the prop counters/video generators to drive an external video circuit. A 4Mhz Z80 and 2Kx8 ram chip were used to generate an 80x24 text display. Something along that line could be done with a register/counter and a ram chip.
