Software Problems
I have Propeller Tool v1.2 loaded on a PC (3 Mhz Pentium 4, plenty of hard drive space, 3 GB of RAM, Windows XP with all updates).· Every time I launch the Prop·Tool (and all· the time it remains open whether I'm working with it or not), I get a Windows·error message dialog box that reads:
"Windows - No Disk
Exception Processing Message c0000013 Parameters 75b6bf9c 4 75b6bf9c 75b6bf9c"
After clicking cancel, the message reappears instantly.· After clicking cancel for the third time, it goes away for about five minutes and then recurs with the same pattern (click cancel three times to clear it for a while, and then it returns).··After clearing, I can go ahead and use the Prop Tool.· It just is annoying to have it pop up constantly.· Afterwards other applications seem to behave weirdly too, like they are out of memory, so I reboot whenever I finish using the Prop Tool
Any suggestions·greatly appreciated.
[noparse][[/noparse]Update by Moderator]· This problem has been resolved: please download Propeller Tool v1.2.5 for the fix.
http://www.parallax.com/tabid/442/Default.aspx
Post Edited By Moderator (Jeff Martin (Parallax)) : 12/6/2008 1:17:28 AM GMT
"Windows - No Disk
Thanks very much.· It's a Media Center PC with built-in slots on the front of the case for SD, Compact Flash cards, etc.· Do you mean that·those might be what·is triggering it?· Because I can't just unplug those like I could an external USB card reader, is there anything that I could do that·would disable the message?
Carl
Post Edited (Carl Lawhon) : 12/3/2008 4:53:23 AM GMT
OR
Maybe someone could rewrite the PropTool v1.2 and fix that and the other (port) problems as well.
This sounds like a question better directed to Jeff Martin. I don't think this is an issue with the empty flash drives or virtual drives since I have a fair amount of those in operation myself.
I wonder if there is a chance that at some time you saved your work to one of the flash drives and didn't properly exit, and it's just something that's hanging. The Propeller tool attempts to recover data from an improper exit or shutdown and generally does a good job, but you might have discovered a circumstance that may confuse the tool.
Have you tried re-installing the Propeller software and/or reverting back to a previous version of the tool?
Beau Schwabe
IC Layout Engineer
Last time I looked at that thing, I swear I saw the ability to configure that as a boot time option. If so, you can boot for Propeller stuff, then boot again for regular media PC use.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
No external reader and Proptool works fine. If I click continue·= (·number of ext drives added), then it works normally.
I unplug the reader and the problem goes away.
Normal, of course, is having to either unplug the protoboard USB and plug it back in or my normal method of opening PC_TERINAL window, then minimizing it. And also the continuing EEPROM Verify Error.
Frustrating, but not terminal.
http://forums.parallax.com/forums/default.aspx?f=25&m=296149
http://forums.parallax.com/showthread.php?p=755835
The actual download page,
www.fnarfbargle.com/bst/
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Can you try running the attached version of the Propeller Tool?
We have been unable to duplicate this error in all the months that we've known about it, despite a number of Media Readers we've tried that supposedly cause the problem.· I'm thinking now that it is somewhat indirectly related to the media reader type, but can't find the source of the error.
The attached Propeller Tool has some added debug code that will trap exceptions (if indeed this is an exception error) and will generate a report for us and will prompt you to allow it to send it to us.
Thanks!
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
FYI, the computer on which I had this problem is also an HP "Media Center" with the built-in slots for various media cards, and like Carl, I have not ever saved any Stamp or Propeller code directly to a removable media device (though I have copied program files to USB drives using the operating system).
Perhaps between you, Carl and I, and with a little experimentation, we can narrow this down to the cause. If it doesn't actually generate a trappable exception error, I think the next step is to compile a custom version for you and Carl that ignores the drive letters that you tell me is your removable media to see if the problem goes away... then we'll know it's definitely caused by scanning that drive.
I apologize for not being able to fix this earlier, but with your help, we may be able to now.
Please PM me with an email address where I can send you a custom exe if need be.
--Jeff Martin
· Parallax, Inc.
I suspect the Prop Tool is looking through some sort of "recently viewed files" list when the startup errors happen...
In fact, I had suspected that before but when I tried it, it wouldn't fail for me.· Maybe I was doing something differently, or maybe I didn't have one of the media readers currently installed that causes the problem.
The only "recently viewed" list that the Propeller Tool uses (that I can think of at the moment) is it's own, based on·the most recent files that were opened.· Perhaps it has something to do with that, but it doesn't make sense unless you had actually opened a file from that location.
That's definitely an area to explore.
Does anyone else get an "exception-like" message in this particular case?· I was unaware that it was an exception error until Carl listed the message... but it looks strange.
--Jeff Martin
· Parallax, Inc.
I have this problem on my machine but only on XP SP2 after uppgrade to SP3 problem is gone.
But I trace this problem to "Delphi" standart dialogs for Open File.
I test many programs and 2 of them was "Delphi" compiled programs and have same problem that Propeler Tools with Removable Media.
Regards Christoffer
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
That's interesting. You mean Delphi-based programs that you wrote yourself? If so, that really sheds some light in an area of the software I wasn't even considering.
--Jeff Martin
· Parallax, Inc.
Not my self ... But 30 days programs from others progam firm.
But sorry I cant give You program names
It was long time ago
Sapieha
That's okay, I appreciate knowing what you traced it too, regardless. Thanks for letting me know, I'll explore that area as well.
--Jeff Martin
· Parallax, Inc.
'Just a few PropSTICK Kit bare PCBs left!
I downloaded and ran the attached version of the Prop Tool.· I got the same error messages on startup as before. Once I cleared them all, I did not receive any prompts to send you a report. However, I did get the following message for the first time:
"WARNING
No library files found in Propeller Tools directory:
C:\DocumentsandSettings\HPAdministrator\MyDocuments\Downloads
Objects that rely on library files (*.spin) will not compile."
I'm guessing this is because the program you sent me just runs rather than installs and doesn't build the libraries?
You must copy it to instal map for Propeller Tools for at it funktion corectly
Sapieha
I guess I'm waiting to hear from Jeff Martin before I make the registry edit suggested.· Can anyone who has made the registry edit say whether it had any other impacts on the function of the card slots?· We do use the compact flash and SD slots for loading photos from digital cameras, so I don't want to disable them or have to reverse some registry edit when we want to use them.· Any reason to be concerned about the registry edit·on those grounds?
Granted, it may be a pragmatic "solution". But Windows users are hardly in a position to be idealists — unless they also have a masochistic streak.
