sx- key editor wont respond
Hello all. My issue is with the sx key editor. Every time I try to run or debug a program the programs freezes and a "Not Responding" error message comes up on my computer screen. I using windows XP and I have lots of free space on my hard drive. Please, if anyone can help me solve this problem it will be very appreciated. Thank you.
I'm not sure if that helps you any...
Often issues come up with faulty hardware (bad memory modules can do all sorts of bad odd things), weak power supply, and just buggy third party drivers. Another huge issue is all the EXTRA junk that people always seem to want to install. Any one that is poorly written can cause issues. Keep it simple and if you don't need it then don't install or run it.
Are you connected via USB or Serial?
So, that being said what else are you running that may conflict? Is anything grabbing the serial port? Are you running a virus scanner that could be blocking access to the serial port?
Is there anything else you can connect to the Serial connection to ensure the port is ok?
For the Serial Key it has to be plugged in and powered by the target device in order to work. The USB version will work either way.
Just a few things to check.
Robert
