(java Error) Button led.java(3) *SOLVED*
Any help
warning) Th public type "Button leD" does not match the name of it containing file.
Post Edited By Moderator (Chris Savage (Parallax)) : 11/24/2008 3:14:11 PM GMT
So name the file "ButtonLed.java" and the class "ButtonLed" too.
JM
In the future please try to use a more descriptive subject for your post. "(No Subject)" doesn’t convey what you need help with. This will often limit potential useful responses as those who can help may never see your message.
Beau Schwabe
IC Layout Engineer
cheers.
i`ll but a subject title next time i start a topic Beau.
in the right upper corner.
regards peter
the led is running.
I am trying to run the Shift74595 chip. I am in need of help.
This is the error message:
[noparse][[/noparse]Java error] Shift74595.java(6,7,8,11,11,11) Syntax: Unexpected symbol ignored.
This is the second time you report this kind of error.
Could your harddisk be failing?
regards peter
And in terms of the DS1620 where do I attach the High Thermostat , Low Thermostat or combined Thermostat pin connections. It is not clear. I know where the dataPin , clock Pin link too. It`s not clear on the chip schematics.
Thanks alot cheers.
