(java Error) Button led.java(3) *SOLVED* — Parallax Forums
HeroHero Posts: 24
edited 2008-12-04 23:14 in General Discussion
Any help
warning) Th public type "Button leD" does not match the name of it containing file. hop.gif
Post Edited By Moderator (Chris Savage (Parallax)) : 11/24/2008 3:14:11 PM GMT
  • jmspaggijmspaggi Posts: 629
    edited 2008-11-21 21:39
    You have to respect the cas. And avoid the space in the name
    So name the file "ButtonLed.java" and the class "ButtonLed" too.
    JM
  • Beau SchwabeBeau Schwabe Posts: 6,575
    edited 2008-11-22 05:54
    Hero,
    In the future please try to use a more descriptive subject for your post. "(No Subject)" doesn’t convey what you need help with. This will often limit potential useful responses as those who can help may never see your message.
    Beau Schwabe
    IC Layout Engineer
  • HeroHero Posts: 24
    edited 2008-11-22 12:32
    Thanks JM. It worked but pressing the button does not put the led on. I think the resistors are incorrectly wired. any links to verifying resistor ks.or could it be another problem i am not aware of?
    cheers.
    i`ll but a subject title next time i start a topic Beau.
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2008-11-22 12:39
    You can change the topic for this thread by clicking the edit icon
    in the right upper corner.
    regards peter
    edited 2008-11-22 13:51
    Cheers every body. I have fixed all my problem.
    the led is running.
    edited 2008-12-04 17:15
    Sorry me again.
    I am trying to run the Shift74595 chip. I am in need of help.
    This is the error message:
    [noparse][[/noparse]Java error] Shift74595.java(6,7,8,11,11,11) Syntax: Unexpected symbol ignored.
    edited 2008-12-04 18:16
    Here is my copy. Compiles ok.
    This is the second time you report this kind of error.
    Could your harddisk be failing?
    regards peter
    Okay, how can I garantee this does`nt happen again? In terms of my hard disk as you said.
    And in terms of the DS1620 where do I attach the High Thermostat , Low Thermostat or combined Thermostat pin connections. It is not clear. I know where the dataPin , clock Pin link too. It`s not clear on the chip schematics.
    Thanks alot cheers.
