examples of how to connect a bread boarded project to a BS2pe motherboard?
Can anyone tell me where I can find some examples of how to connect a bread boarded project to a BS2pe motherboard?
Thank you.
[noparse][[/noparse]Subject Added By Moderator]
Post Edited By Moderator (Chris Savage (Parallax)) : 11/19/2008 12:08:23 AM GMT
Thank you.
http://www.parallax.com/Store/Microcontrollers/BASICStampDevelopmentBoards/tabid/137/CategoryID/12/List/0/SortField/0/Level/a/ProductID/451/Default.aspx
··Dave
Dave Andreae
Parallax Tech Support·
As an alternative, DigiKey carries compatible daughterboard connector shells and preterminated wire inserts that you can use to make the transfer. The shells are part number H2917-ND. The best deal on the wires is part number H3AAT-10112-S6-ND. Becasue of DigiKey's weird pricing structure, it's cheaper to buy dual-terminated 12" wires and cut them in half than to buy singly-terminated 6" wires. Go figure.
You can save money over DigiKey, though, by using Parallax's Daughterboard Extension Cable and just cutting the female receptacle off the end.
The $15 Power Input, 3-pin Header I/O Daughterboard brings these pins out to three-pin headers, plus gives more power options.
