Best choice for the job? 16 I/O + 57K serial
I have an application in mind, but I have a couple requirements that I think steer me towards the larger propeller chips as the only solution.· Specifically, I need 57K baud·serial port (it'll be on RS485 with other devices that run at 57K - can't change that) and beyond the serial, I need 16 fully available output pins.
I'd like to use something like the Stamp Controller interface board, since my 16 outputs will connect to an OPTO-22 compatible bank of SSRs, but everything I've read says that the BS2 modules are limited to 9600 or 19200 baud.
What would you use?
What would you use?
Oh, and the Prop Plug is the Daily Deal: $15 instead of the usual $25. Great time to jump in.
Post Edited (sylvie369) : 11/14/2008 5:14:26 PM GMT
