Best choice for the job? 16 I/O + 57K serial — Parallax Forums
CarlDCarlD Posts: 7
edited 2008-11-14 16:45 in General Discussion
I have an application in mind, but I have a couple requirements that I think steer me towards the larger propeller chips as the only solution.· Specifically, I need 57K baud·serial port (it'll be on RS485 with other devices that run at 57K - can't change that) and beyond the serial, I need 16 fully available output pins.
I'd like to use something like the Stamp Controller interface board, since my 16 outputs will connect to an OPTO-22 compatible bank of SSRs, but everything I've read says that the BS2 modules are limited to 9600 or 19200 baud.
What would you use?
  • Jay KickliterJay Kickliter Posts: 446
    edited 2008-11-14 16:14
    I'd use the Propeller regardless. The fact that it has 8 cores and can do parallel processing is an added bonus. Plus it's pretty easy to program.
  • CarlDCarlD Posts: 7
    edited 2008-11-14 16:36
    I must admit, as an old-time bit banger, the 8-core propeller is pretty interesting.· That's definitely the way I'm leaning - still more stuff to read though.· Thanks for the input.
  • sylvie369sylvie369 Posts: 1,622
    In my limited playing around with the Propeller so far, I'd say in comparison with a Stamp, it's harder to do the easy stuff, and WAY easier to do the hard stuff on a Propeller.
    Oh, and the Prop Plug is the Daily Deal: $15 instead of the usual $25. Great time to jump in.
    Post Edited (sylvie369) : 11/14/2008 5:14:26 PM GMT
