Boe-Bot/Tank Tread/CMU-Cam problems
I have a Boe-Bot with the tank tread kit and a CMU-Cam that I am trying to get working. I am running the demo code from the CMU-Cam, and the program works, the calibration works and the color tracking works, but the servos refuse to work.
This code is what I am using:
On a topic of lesser importance, I am also trying to get code working for the gripper tool, if anyone has any tips.
Thank you in advance
'{$STAMP BS2}
'{$PBASIC 2.5}
' CMUcam1 BoeBot AppMod 1.2 Demo Program
' Copyright 2006, Seattle Robotics
' Basic Stamp 2
' CMUcam1 jumpered for 9600 Baud
' RA Nucci 07/13/2006
' Setup pins for buttons
INPUT 6
INPUT 8
HIGH 6
HIGH 8
RcvData VAR Byte(10) ' Array
SaveColorData VAR Byte(6) ' Array
Result VAR Word
N VAR Byte ' General purpose counter variable
LostTrack VAR Nib
Switch VAR Nib
Debounce VAR Nib
Function VAR Nib
Main:
' Pause for CMUcam1 startup
FOR N = 2 TO 5 ' Flash all LED's during pause
SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]255]
PAUSE 400
SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0]
PAUSE 400
NEXT
FREQOUT 10, 400, 2500 ' Beep to indicate ready
ProgTop:
' Select function from push buttons
GOSUB GetButton
Debounce=Switch
GOSUB GetButton
' Get button press twice and compare if not the same repeat
IF Debounce <> Switch THEN ProgTop
IF Switch = 2 THEN ' If Go/Stop button pushed then beep
FREQOUT 10, 400, 2500 ' beep
ENDIF
BRANCH Switch, [noparse][[/noparse]ProgTop,Buttonselect,Execute]
Buttonselect:
Function = Function + 1
IF Function > 9 THEN
Function = 1
ENDIF
PAUSE 300
SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]DCD(Function-1)]
GOTO ProgTop
Execute:
BRANCH Function, [noparse][[/noparse]ProgTop,Calibrate,SaveColor,TrackColor,Avoid,Adapt,FollowLine,Point,Color]
GOTO ProgTop
GetButton:
Switch=0
IF IN6 = 0 THEN
Switch = 1 ' Select button pressed
RETURN
ENDIF
IF IN8 = 0 THEN
Switch = 2 ' GO/Stop button pressed
RETURN
ENDIF
IF IN8 = 0 AND IN6 = 0 THEN
Switch = 3 ' Both buttons pressed at the same time
ENDIF
RETURN
' Track the color previously saved in EEPROM
TrackColor:
GOSUB ConfigureCMUcam
' Read EEPROM into SaveColorData array
READ 0, SaveColorData(0)
READ 1, SaveColorData(1)
READ 2, SaveColorData(2)
READ 3, SaveColorData(3)
READ 4, SaveColorData(4)
READ 5, SaveColorData(5)
' Set Track Color values from EEPROM
SEROUT 7,84,[noparse][[/noparse]"TC"]
SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(0)]
SEROUT 7,84,[noparse][[/noparse]" "]
SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(1)]
SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(2)]
SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(3)]
SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(4)]
SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(5),CR]
PAUSE 200
TopTrack:
SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' All LED's off
GOSUB GetButton ' Check for stop button press
IF Switch = 2 THEN' Switch 2 is stop button
' Two beeps for Stop
SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]DCD (Function-1)]
PAUSE 200
PAUSE 200
' Reset the green tracking LED
SEROUT 7, 84, [noparse][[/noparse]"L1 0",CR] ' Green LED off
PAUSE 100
SEROUT 7, 84, [noparse][[/noparse]"L1 2",CR] ' Green LED auto mode
PAUSE 100
GOTO ProgTop
ENDIF
' Send command - Track color (with no arguments) -
' will track last color grabbed by TW command
SEROUT 7, 84, [noparse][[/noparse]"TC",CR]
SERIN 9, 84, [noparse][[/noparse]STR RcvData\10]
PAUSE 100
' 45 is aprox H center, 70 is aprox V center
' Track and follow logic
IF Function = 3 THEN
IF RCVData(2) > 65 AND RcvData(9) > 25 THEN RotateLeft
IF RCVData(2) < 25 AND RcvData(9) > 25 THEN RotateRight
IF RCVData(7) > 120 AND RcvData(9) > 25 THEN Bwd
IF RCVData(7) < 60 AND RcvData(9) > 25 THEN Fwd
ENDIF
' Move and avoid logic
IF Function = 4 THEN
IF RCVData(3) > 50 AND RcvData(9) > 20 THEN Fwd
IF RCVData(3) < 50 THEN BackUp
IF RcvData(9) <= 20 THEN BackUp
ENDIF
' Adaptive tracking logic
IF Function = 5 THEN
IF LostTrack > 6 THEN TW
LostTrack = LostTrack + 1
IF RcvData(9) > 25 THEN LostTrack = 0
ENDIF
' Line Following logic
IF Function = 6 THEN
IF RCVData(2) > 50 AND RcvData(9) > 5 THEN TurnLeft ' 45
IF RCVData(2) < 40 AND RcvData(9) > 5 THEN TurnRight ' 45
IF RCVData(2) >= 40 AND RCVData(2) =< 50 AND RcvData(9) > 5 THEN Fwd
ENDIF
' Finger point logic
IF Function = 7 THEN
IF RCVData(2) > 60 AND RcvData(9) > 25 THEN RotateRight ' Centroid X
IF RCVData(2) < 30 AND RcvData(9) > 25 THEN RotateLeft ' Centroid X
IF RCVData(3) > 30 AND RcvData(9) > 15 THEN Bwd ' Centroid Y
ENDIF
' Color logic
IF Function = 8 THEN
SEROUT 7, 84, [noparse][[/noparse]"TC 30 240 16 30 16 30",CR] ' Red
IF RcvData(9) > 20 THEN
SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]195] ' All Red LED's on
PAUSE 500
ENDIF
SEROUT 7, 84, [noparse][[/noparse]"TC 16 40 30 240 90 170",CR] ' Green
SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]24] ' All Green LED's on
PAUSE 500
ENDIF
SEROUT 7, 84, [noparse][[/noparse]"TC 200 240 200 240 16 50",CR] ' Yellow
SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]36] ' All Yellow LED's on
PAUSE 500
ENDIF
ENDIF
' Flash LED's to show bottom of tracking loop
SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]129] ' 100000001
GOTO TopTrack
' Calibrate CMUcam1 for lighting conditions
Calibrate:
' Reset CMUcam1
SEROUT 7, 84, [noparse][[/noparse]"RS",CR]
PAUSE 200
' Turn on auto adjust
SEROUT 7, 84, [noparse][[/noparse]"CR 18 44",CR]
PAUSE 100
' Delay loop for CMUcam1 to auto adjust to lighting conditions
FOR N = 2 TO 255
PAUSE 100
SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]DCD (N)]
GOSUB GetButton ' Check for stop button pressed
IF Switch = 2 THEN EXIT ' Switch 2 is stop button
NEXT
SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' 000000000
' Turn off auto adjust
SEROUT 7, 84, [noparse][[/noparse]"CR 18 44 19 32",CR]
PAUSE 100
SHIFTOUT 5,11,MSBFIRST, ' 100000000
PAUSE 300
GOTO ProgTop
SaveColor:
' sample and save color
SEROUT 7,84,[noparse][[/noparse]"PM 1",CR]
PAUSE 100
' Set a small window in center
SEROUT 7,84,[noparse][[/noparse]"SW 30 54 50 90",CR]
PAUSE 100
' Set raw mode 3
SEROUT 7,84,[noparse][[/noparse]"RM 3",CR]
PAUSE 100
'set minimun and maximun values
SaveColorData(0)=16
SaveColorData(1)=240
SaveColorData(2)=16
SaveColorData(3)=240
SaveColorData(4)=16
SaveColorData(5)=240
' Get Mean
SEROUT 7,84,[noparse][[/noparse]"GM",CR]
SERIN 9,84, [noparse][[/noparse]STR rcvdata\8]
PAUSE 200
IF rcvdata(2)<=46 THEN gm1
SaveColorData(0)=(rcvdata(2)-30)
gm1:
IF rcvdata(3)<=46 THEN gm2
SaveColorData(2)=(rcvdata(3)-30)
gm2:
IF rcvdata(4)<=46 THEN gm3
saveColorData(4)=(rcvdata(4)-30)
gm3:
IF rcvdata(2)>210 THEN gm4
saveColorData(1)=(rcvdata(2)+30)
gm4:
IF rcvdata(3)>240 THEN gm5
saveColorData(3)=(rcvdata(3)+30)
gm5:
IF rcvdata(4)>240 THEN gm6
saveColorData(5)=(rcvdata(4)+30)
gm6:
' Set raw mode to 0
SEROUT 7,84,[noparse][[/noparse]"RM 0",CR]
PAUSE 100
' Return window to full size
SEROUT 7,84,[noparse][[/noparse]"SW",CR]
' Write color tracking range values to end of EEPROM
WRITE 0,saveColorData(0)
WRITE 1,saveColorData(1)
WRITE 2,saveColorData(2)
WRITE 3,saveColorData(3)
WRITE 4,saveColorData(4)
WRITE 5,saveColorData(5)
' Two beeps
PAUSE 400
PAUSE 400
GOTO ProgTop
Avoid:
SEROUT 7,84,[noparse][[/noparse]"TW",CR]
PAUSE 1000 ' Wait 1 second for TW
GOTO TopTrack
Adapt:
TW:
SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]255] ' All LED's on
FREQOUT 10, 150, 2500 ' Beep
PAUSE 100
SEROUT 7,84,[noparse][[/noparse]"TW",CR] ' Send Track Window command
PAUSE 1000 ' Wait 1 second for TW to complete
LostTrack = 0 ' Reset LostTrack counter
GOTO TopTrack
FollowLine:
SEROUT 7,84,[noparse][[/noparse]"TC 16 50 16 50 16 50",CR]' Black line color
PAUSE 100
GOTO Toptrack
Point:
SEROUT 7,84,[noparse][[/noparse]"TC 200 240 180 240 50 100",CR] ' Skin color
PAUSE 100
GOTO Toptrack
Color:
GOTO Toptrack
ConfigureCMUcam:
SEROUT 7,84,[noparse][[/noparse]"PM 1",CR]' Poll Mode
PAUSE 100
SEROUT 7,84,[noparse][[/noparse]"RM 3",CR]' Raw Mode
PAUSE 100
SEROUT 7,84,[noparse][[/noparse]"CR 32 8",CR]' White Balance smart mode
PAUSE 100
RETURN
BackUp:
' backup
FOR n = 1 TO 15
PULSOUT 14,1000 ' **
PULSOUT 15,500 ' **
PAUSE 15
NEXT
PAUSE 200
' rotate about 90 degrees
SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]32]
FOR n = 1 TO 100
PULSOUT 15,1000 ' **
NEXT
GOTO TopTrack
RotateLeft:
FOR n = 1 TO 10
PULSOUT 14,500 ' **
PULSOUT 15,500 ' **
NEXT
GOTO TopTrack
RotateRight:
FOR n = 1 TO 10
NEXT
GOTO TopTrack
TurnLeft:
FOR n = 1 TO 40
PULSOUT 14,500 ' **
PULSOUT 15,750 ' **
NEXT
GOTO TopTrack
TurnRight:
FOR n = 1 TO 40
PULSOUT 14,750 ' **
NEXT
GOTO TopTrack
Bwd:
FOR n = 1 TO 10
PULSOUT 15,500 ' **
PAUSE 15
NEXT
GOTO TopTrack
Fwd:
FOR n = 1 TO 10
PULSOUT 14,500 ' **
PAUSE 15
NEXT
GOTO TopTrack
If you don't do the repeat, the servo is not going to move. It has a very simple comparator on-board, and each input pulse it compares with its current position, and moves the 'output shaft' a little to compensate. Thus you need MULTIPLE 20 mSec "refreshes" of the Servo signal to get anything to happen.
Secondly, for this to work the BS2 and the Servo MUST share a 'common ground', otherwise the BS2 servo control signal is "floating" compared to the Servo and the Servo can't read it.
I am sorry to say that that did not help. I can't see where the problem is. This is the demo code that comes with the camera.
Post Edited (Chefdude548) : 11/14/2008 5:42:18 PM GMT
