Boe-Bot/Tank Tread/CMU-Cam problems
I have a Boe-Bot with the tank tread kit and a CMU-Cam that I am trying to get working. I am running the demo code from the CMU-Cam, and the program works, the calibration works and the color tracking works, but the servos refuse to work.
This code is what I am using:
On a topic of lesser importance, I am also trying to get code working for the gripper tool, if anyone has any tips.
Thank you in advance
'{$STAMP BS2} '{$PBASIC 2.5} ' CMUcam1 BoeBot AppMod 1.2 Demo Program ' Copyright 2006, Seattle Robotics ' Basic Stamp 2 ' CMUcam1 jumpered for 9600 Baud ' RA Nucci 07/13/2006 ' Setup pins for buttons INPUT 6 INPUT 8 HIGH 6 HIGH 8 RcvData VAR Byte(10) ' Array SaveColorData VAR Byte(6) ' Array Result VAR Word N VAR Byte ' General purpose counter variable LostTrack VAR Nib Switch VAR Nib Debounce VAR Nib Function VAR Nib Main: ' Pause for CMUcam1 startup FOR N = 2 TO 5 ' Flash all LED's during pause SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]255] PAUSE 400 SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] PAUSE 400 NEXT FREQOUT 10, 400, 2500 ' Beep to indicate ready ProgTop: ' Select function from push buttons GOSUB GetButton Debounce=Switch GOSUB GetButton ' Get button press twice and compare if not the same repeat IF Debounce <> Switch THEN ProgTop IF Switch = 2 THEN ' If Go/Stop button pushed then beep FREQOUT 10, 400, 2500 ' beep ENDIF BRANCH Switch, [noparse][[/noparse]ProgTop,Buttonselect,Execute] Buttonselect: Function = Function + 1 IF Function > 9 THEN Function = 1 SHIFTOUT 5,11,MSBFIRST, ENDIF PAUSE 300 SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]DCD(Function-1)] GOTO ProgTop Execute: BRANCH Function, [noparse][[/noparse]ProgTop,Calibrate,SaveColor,TrackColor,Avoid,Adapt,FollowLine,Point,Color] GOTO ProgTop GetButton: Switch=0 IF IN6 = 0 THEN Switch = 1 ' Select button pressed RETURN ENDIF IF IN8 = 0 THEN Switch = 2 ' GO/Stop button pressed RETURN ENDIF IF IN8 = 0 AND IN6 = 0 THEN Switch = 3 ' Both buttons pressed at the same time ENDIF RETURN ' Track the color previously saved in EEPROM TrackColor: GOSUB ConfigureCMUcam ' Read EEPROM into SaveColorData array READ 0, SaveColorData(0) READ 1, SaveColorData(1) READ 2, SaveColorData(2) READ 3, SaveColorData(3) READ 4, SaveColorData(4) READ 5, SaveColorData(5) ' Set Track Color values from EEPROM SEROUT 7,84,[noparse][[/noparse]"TC"] SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(0)] SEROUT 7,84,[noparse][[/noparse]" "] SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(1)] SEROUT 7,84,[noparse][[/noparse]" "] SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(2)] SEROUT 7,84,[noparse][[/noparse]" "] SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(3)] SEROUT 7,84,[noparse][[/noparse]" "] SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(4)] SEROUT 7,84,[noparse][[/noparse]" "] SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(5),CR] PAUSE 200 TopTrack: SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' All LED's off GOSUB GetButton ' Check for stop button press IF Switch = 2 THEN' Switch 2 is stop button ' Two beeps for Stop SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]DCD (Function-1)] PAUSE 200 FREQOUT 10, 400, 2500 PAUSE 200 FREQOUT 10, 400, 2500 ' Reset the green tracking LED SEROUT 7, 84, [noparse][[/noparse]"L1 0",CR] ' Green LED off PAUSE 100 SEROUT 7, 84, [noparse][[/noparse]"L1 2",CR] ' Green LED auto mode PAUSE 100 GOTO ProgTop ENDIF ' Send command - Track color (with no arguments) - ' will track last color grabbed by TW command SEROUT 7, 84, [noparse][[/noparse]"TC",CR] SERIN 9, 84, [noparse][[/noparse]STR RcvData\10] PAUSE 100 ' 45 is aprox H center, 70 is aprox V center ' Track and follow logic IF Function = 3 THEN IF RCVData(2) > 65 AND RcvData(9) > 25 THEN RotateLeft IF RCVData(2) < 25 AND RcvData(9) > 25 THEN RotateRight IF RCVData(7) > 120 AND RcvData(9) > 25 THEN Bwd IF RCVData(7) < 60 AND RcvData(9) > 25 THEN Fwd ENDIF ' Move and avoid logic IF Function = 4 THEN IF RCVData(3) > 50 AND RcvData(9) > 20 THEN Fwd IF RCVData(3) < 50 THEN BackUp IF RcvData(9) <= 20 THEN BackUp ENDIF ' Adaptive tracking logic IF Function = 5 THEN IF RCVData(2) > 65 AND RcvData(9) > 25 THEN RotateLeft IF RCVData(2) < 25 AND RcvData(9) > 25 THEN RotateRight IF RCVData(7) < 60 AND RcvData(9) > 25 THEN Fwd IF LostTrack > 6 THEN TW LostTrack = LostTrack + 1 IF RcvData(9) > 25 THEN LostTrack = 0 ENDIF ' Line Following logic IF Function = 6 THEN IF RCVData(2) > 50 AND RcvData(9) > 5 THEN TurnLeft ' 45 IF RCVData(2) < 40 AND RcvData(9) > 5 THEN TurnRight ' 45 IF RCVData(2) >= 40 AND RCVData(2) =< 50 AND RcvData(9) > 5 THEN Fwd ENDIF ' Finger point logic IF Function = 7 THEN IF RCVData(2) > 60 AND RcvData(9) > 25 THEN RotateRight ' Centroid X IF RCVData(2) < 30 AND RcvData(9) > 25 THEN RotateLeft ' Centroid X IF RCVData(3) > 30 AND RcvData(9) > 15 THEN Bwd ' Centroid Y ENDIF ' Color logic IF Function = 8 THEN SEROUT 7, 84, [noparse][[/noparse]"TC 30 240 16 30 16 30",CR] ' Red SERIN 9, 84, [noparse][[/noparse]STR RcvData\10] IF RcvData(9) > 20 THEN SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]195] ' All Red LED's on PAUSE 500 SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' All LED's off ENDIF SEROUT 7, 84, [noparse][[/noparse]"TC 16 40 30 240 90 170",CR] ' Green SERIN 9, 84, [noparse][[/noparse]STR RcvData\10] IF RcvData(9) > 20 THEN SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]24] ' All Green LED's on PAUSE 500 SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' All LED's off ENDIF SEROUT 7, 84, [noparse][[/noparse]"TC 200 240 200 240 16 50",CR] ' Yellow SERIN 9, 84, [noparse][[/noparse]STR RcvData\10] IF RcvData(9) > 20 THEN SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]36] ' All Yellow LED's on PAUSE 500 SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' All LED's off ENDIF ENDIF ' Flash LED's to show bottom of tracking loop SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]129] ' 100000001 GOTO TopTrack ' Calibrate CMUcam1 for lighting conditions Calibrate: ' Reset CMUcam1 SEROUT 7, 84, [noparse][[/noparse]"RS",CR] PAUSE 200 ' Turn on auto adjust SEROUT 7, 84, [noparse][[/noparse]"CR 18 44",CR] PAUSE 100 ' Delay loop for CMUcam1 to auto adjust to lighting conditions FOR N = 2 TO 255 PAUSE 100 SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]DCD (N)] GOSUB GetButton ' Check for stop button pressed IF Switch = 2 THEN EXIT ' Switch 2 is stop button NEXT SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' 000000000 ' Turn off auto adjust SEROUT 7, 84, [noparse][[/noparse]"CR 18 44 19 32",CR] PAUSE 100 GOSUB ConfigureCMUcam SHIFTOUT 5,11,MSBFIRST, ' 100000000 FREQOUT 10, 400, 2500 PAUSE 300 FREQOUT 10, 400, 2500 GOTO ProgTop SaveColor: ' sample and save color SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] SEROUT 7,84,[noparse][[/noparse]"PM 1",CR] PAUSE 100 ' Set a small window in center SEROUT 7,84,[noparse][[/noparse]"SW 30 54 50 90",CR] PAUSE 100 ' Set raw mode 3 SEROUT 7,84,[noparse][[/noparse]"RM 3",CR] PAUSE 100 'set minimun and maximun values SaveColorData(0)=16 SaveColorData(1)=240 SaveColorData(2)=16 SaveColorData(3)=240 SaveColorData(4)=16 SaveColorData(5)=240 ' Get Mean SEROUT 7,84,[noparse][[/noparse]"GM",CR] SERIN 9,84, [noparse][[/noparse]STR rcvdata\8] PAUSE 200 IF rcvdata(2)<=46 THEN gm1 SaveColorData(0)=(rcvdata(2)-30) gm1: IF rcvdata(3)<=46 THEN gm2 SaveColorData(2)=(rcvdata(3)-30) gm2: IF rcvdata(4)<=46 THEN gm3 saveColorData(4)=(rcvdata(4)-30) gm3: IF rcvdata(2)>210 THEN gm4 saveColorData(1)=(rcvdata(2)+30) gm4: IF rcvdata(3)>240 THEN gm5 saveColorData(3)=(rcvdata(3)+30) gm5: IF rcvdata(4)>240 THEN gm6 saveColorData(5)=(rcvdata(4)+30) gm6: ' Set raw mode to 0 SEROUT 7,84,[noparse][[/noparse]"RM 0",CR] PAUSE 100 ' Return window to full size SEROUT 7,84,[noparse][[/noparse]"SW",CR] ' Write color tracking range values to end of EEPROM WRITE 0,saveColorData(0) WRITE 1,saveColorData(1) WRITE 2,saveColorData(2) WRITE 3,saveColorData(3) WRITE 4,saveColorData(4) WRITE 5,saveColorData(5) GOSUB ConfigureCMUcam SHIFTOUT 5,11,MSBFIRST, ' Two beeps FREQOUT 10, 400, 2500 PAUSE 400 FREQOUT 10, 400, 2500 PAUSE 400 GOTO ProgTop Avoid: GOSUB ConfigureCMUcam SEROUT 7,84,[noparse][[/noparse]"TW",CR] PAUSE 1000 ' Wait 1 second for TW GOTO TopTrack Adapt: GOSUB ConfigureCMUcam TW: SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]255] ' All LED's on FREQOUT 10, 150, 2500 ' Beep PAUSE 100 FREQOUT 10, 150, 2500 ' Beep SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' All LED's off SEROUT 7,84,[noparse][[/noparse]"TW",CR] ' Send Track Window command PAUSE 1000 ' Wait 1 second for TW to complete LostTrack = 0 ' Reset LostTrack counter GOTO TopTrack FollowLine: GOSUB ConfigureCMUcam SEROUT 7,84,[noparse][[/noparse]"TC 16 50 16 50 16 50",CR]' Black line color PAUSE 100 GOTO Toptrack Point: GOSUB ConfigureCMUcam SEROUT 7,84,[noparse][[/noparse]"TC 200 240 180 240 50 100",CR] ' Skin color PAUSE 100 GOTO Toptrack Color: GOSUB ConfigureCMUcam GOTO Toptrack ConfigureCMUcam: SEROUT 7,84,[noparse][[/noparse]"PM 1",CR]' Poll Mode PAUSE 100 SEROUT 7,84,[noparse][[/noparse]"RM 3",CR]' Raw Mode PAUSE 100 SEROUT 7,84,[noparse][[/noparse]"CR 32 8",CR]' White Balance smart mode PAUSE 100 RETURN BackUp: ' backup SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]195] FOR n = 1 TO 15 PULSOUT 14,1000 ' ** PULSOUT 15,500 ' ** PAUSE 15 NEXT PAUSE 200 ' rotate about 90 degrees SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]32] FOR n = 1 TO 100 PULSOUT 14,1000 ' ** PULSOUT 15,1000 ' ** NEXT GOTO TopTrack RotateLeft: SHIFTOUT 5,11,MSBFIRST, FOR n = 1 TO 10 PULSOUT 14,500 ' ** PULSOUT 15,500 ' ** NEXT GOTO TopTrack RotateRight: SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]32] FOR n = 1 TO 10 PULSOUT 14,1000 ' ** PULSOUT 15,1000 ' ** NEXT GOTO TopTrack TurnLeft: SHIFTOUT 5,11,MSBFIRST, FOR n = 1 TO 40 PULSOUT 14,500 ' ** PULSOUT 15,750 ' ** NEXT GOTO TopTrack TurnRight: SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]32] FOR n = 1 TO 40 PULSOUT 14,750 ' ** PULSOUT 15,1000 ' ** NEXT GOTO TopTrack Bwd: SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]195] FOR n = 1 TO 10 PULSOUT 14,1000 ' ** PULSOUT 15,500 ' ** PAUSE 15 NEXT GOTO TopTrack Fwd: SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]24] FOR n = 1 TO 10 PULSOUT 14,500 ' ** PULSOUT 15,1000 ' ** PAUSE 15 NEXT GOTO TopTrack
If you don't do the repeat, the servo is not going to move. It has a very simple comparator on-board, and each input pulse it compares with its current position, and moves the 'output shaft' a little to compensate. Thus you need MULTIPLE 20 mSec "refreshes" of the Servo signal to get anything to happen.
Secondly, for this to work the BS2 and the Servo MUST share a 'common ground', otherwise the BS2 servo control signal is "floating" compared to the Servo and the Servo can't read it.
I am sorry to say that that did not help. I can't see where the problem is. This is the demo code that comes with the camera.
Post Edited (Chefdude548) : 11/14/2008 5:42:18 PM GMT
