Value in BS2 emulator Shiftout?
Hi, can anyone tell me what the parameter of value does in the following code? My guess is that it tells when to write the data (clock high or low), but I'm not sure.
PUB SHIFTOUT (Dpin, Cpin, Value, Mode, Bits)| bitNum
Shift data out, master clock, for mode use ObjName#LSBFIRST, #MSBFIRST
Clock rate is ~16Kbps. Use at 80MHz only is recommended.
BS2.SHIFTOUT(5,6,"B",BS2#LSBFIRST,8)
outa[noparse][[/noparse]Dpin]:=0 ' Data pin = 0
dira[noparse][[/noparse]Dpin]~~ ' Set data as output
outa[noparse][[/noparse]Cpin]:=0
dira[noparse][[/noparse]Cpin]~~
If Mode == LSBFIRST ' Send LSB first
REPEAT Bits
outa[noparse][[/noparse]Dpin] := Value ' Set output
Value := Value >> 1 ' Shift value right
!outa[noparse][[/noparse]Cpin] ' cycle clock
waitcnt(1000 + cnt) ' delay
elseIf Mode == MSBFIRST ' Send MSB first
REPEAT Bits
outa[noparse][[/noparse]Dpin] := Value >> (bits-1) ' Set output
Value := Value << 1 ' Shift value right
outa[noparse][[/noparse]Dpin]~ ' Set data to low
no it is the datavalue that will be sended out as a serial bitstream
best regards
Stefan
