Value in BS2 emulator Shiftout? — Parallax Forums
SRLMSRLM Posts: 5,045
edited 2008-11-11 16:49 in Propeller 1
Hi, can anyone tell me what the parameter of value does in the following code? My guess is that it tells when to write the data (clock high or low), but I'm not sure.
PUB SHIFTOUT (Dpin, Cpin, Value, Mode, Bits)| bitNum
   Shift data out, master clock, for mode use ObjName#LSBFIRST, #MSBFIRST
   Clock rate is ~16Kbps.  Use at 80MHz only is recommended.
     BS2.SHIFTOUT(5,6,"B",BS2#LSBFIRST,8)
    outa[noparse][[/noparse]Dpin]:=0                                          ' Data pin = 0
    dira[noparse][[/noparse]Dpin]~~                                           ' Set data as output
    outa[noparse][[/noparse]Cpin]:=0
    dira[noparse][[/noparse]Cpin]~~
    If Mode == LSBFIRST                                    ' Send LSB first
       REPEAT Bits
          outa[noparse][[/noparse]Dpin] := Value                              ' Set output
          Value := Value >> 1                              ' Shift value right
          !outa[noparse][[/noparse]Cpin]                                      ' cycle clock
          waitcnt(1000 + cnt)                              ' delay
    elseIf Mode == MSBFIRST                                ' Send MSB first
       REPEAT Bits
          outa[noparse][[/noparse]Dpin] := Value >> (bits-1)                  ' Set output
          Value := Value << 1                              ' Shift value right
    outa[noparse][[/noparse]Dpin]~                                            ' Set data to low
    edited 2008-11-11 14:14
    Hello SRLM,
    no it is the datavalue that will be sended out as a serial bitstream
    best regards
    Stefan
  • SRLMSRLM Posts: 5,045
    Ah. I'm not sure what I was thinking. Of course I need to output some sort of data with a Shiftout. Thank you.
