What soldering iron should I buy? How best to solder protoboards?
Hi all,
I've got my Propeller-based data system working pretty well (thanks to all on the forum who've been so kind to hold my hand these past few months) and I've got my photomultipliers working well with their amps and power controllers. However, in between those two zones of relative competence is a line of comparators that have been, to put it euphemistically, "teaching me a lot about electronic design." More specifically, what NOT to do. Much to my dismay, I can't really get ultra fast comparator chips to remain stable and give good clean signals when plugged into solderless protoboards (duh), so it looks like I'm doomed to link up a big ole mess of comparators using (que the chorus of female screamers) A SOLDERING IRON.
This would be to solder DIP type through-hole chips on what I think will be plated through hole protoboards with a ground plane on one side. Problem is, I don't know anything about soldering irons. The only type I've ever used is the el cheapo kind I've bought at Radio Shack. And I dread the thought of making hundreds of connections using one of those hobbyist torture devices.
Okay, so once I start down the slippery slope of soldering dozens of DIP chips, I'm guessing I'll want to solder the Propeller Chip, too. And maybe someday even go insane and try my hand at SMTs, etc.
So what type of iron should I buy? What sort of solder should I use? If you've got specific brands and model numbers, that would be great. As usual, I'm flying by the seat of my pants here, so the more information, the better. Once I learned I needed a ground plane and super-short leads, I had a nervous breakdown. I'm doing better, though. After weeks of solderphobia therapy, I think I'm ready to face my fears. Any suggestions would be greatly appreciated.
a thousand thanks,
Mark
a thousand thanks,
Mark
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
Jim Fouch
FOUCH SOFTWARE
Soldering a few hundred connections is no big deal. For tin/lead solder, a 63/37 alloy is best although 60/40 works OK. Don't let anyone sell you 50/50 for electronics - 50/50 is for plumbing! Use rosin core of course, .031 diameter or less.
I have never used non-lead solder for electronics so I can't make any recommendations there although I find that non-lead solder works great for plumbing. I have been soldering with tin/lead solder for over 60 years and have enough to last me the rest of my life so I don't think I will change now.
Main thing to remember is which end of the iron is hot and which end you hold on to.
Jerry
The poorly constructed, tip rotates uncontrollably.
If you can't spring for something other than these knock offs, then spend $20 at Rat Shack and buy a 25watt until you can.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
- Rick
www.howardelectronics.com
I am eying the Goot PX-201 70watt variable temp lead free iron for $49.95. I have seen a few good recommendations for it.
John
President Dale: I want the people to know that they still have 2 out of 3 branches of the government working for them, and that ain't bad.
Mars Attacks! (1996)
thanks for contributing your wisdom and experience on the soldering issue. I'm guessing the devil is in the details, so your specific recommendations have been much appreciated! If only one of you geniuses out there could invent a solderless breadboard that didn't have all sorts of issues at high frequency. Isn't there something you Einsteins could do with nanotech or gelatinous gooey buckyball materials or something? My solderphobia therapy sessions are working, I suppose, but they cost a fortune. The worst part is having to sit in the waiting room with all the other phobia sufferers, many of whom are terrified of people like me.
bless your little hearts,
Mark
There's nothing wrong with these - I've been using a 15 watt Radio Shack soldering iron (with grounded tip) for 20 years. Radio Shack still sells this model for under $10 and I've must have soldered more than a dozen boards and thousands of solder joints - it still works great. I use rosin solder paste gel and 60/40 Sn/Pb solder, and clean the boards with a toothbrush and Isopropyl Alcohol after soldering, and they're all still working. Don't forget to replace the tip (about $2) when they wear out.
Chris Savage
Parallax Engineering
thanks for your inputs on the el cheapo soldering iron. Maybe I'll stick with it for now and just get a new tip for it. I never thought about getting a new tip.
thanks for the tip!
Mark
It might be the Information Age but the Eon of Ignorance has yet to end.
For the price, I don't think you can beat it for a general purpose electronics soldering iron.
I also recommend the tip cleaner that looks like a brass brillo pad instead of a wet sponge. The wet sponge can really drop the temperature of the tip. Plus to you don't need to fuss about looking for water to wet it.
Bean.
"The welfare of the people in particular has always been the alibi of tyrants." ~ Camus
www.iElectronicDesigns.com
Post Edited (Bean (Hitt Consulting)) : 11/12/2008 5:43:41 PM GMT
dont soldier the prop if you dont have to
definately put it in a socket
Parallax posesses power beyond belief.
Believe in it.
http://www.cooperhandtools.com/brands/electronic_applications/weller/instructions/tip%20care%20and%20use.pdf
Dan
On the "commercial side": Ersa I-Con stations. They have come down in price to $295. We use them for tin/lead and lead free. Our handsoldering defects virtually disappeared (even for lead free) once we started using these stations. The precise temperature stability makes this station indispensable. Even beats out my old friend, MetCal.
~~ dRu ~~
Oops I see it's been superceeded by Xytronic 169D, same features and now $30 cheaper (now $99).
Paul Baker
Post Edited (Paul Baker (Parallax)) : 11/13/2008 11:34:49 PM GMT
I actually started using the liquid rosin flux to help with the water soluable type flux type solder. It helped alot, but I'm not happy with the way things look, much less having to clean everything up.
Anyone have suggestions on what I could use? I thought the article I posted from Cooper tools gave a good description of the problems associated with the differnt types of solder.
Open to new ideas,
Dan
lead free, no-clean solder
Is good solder but you have to use a little more heat than you would use with 60/40· rosin solder
also when soldering non copper wire it harder to solder
Paul Baker
I second what you say about the Xytronic 137ESD I have two of them and they work real good
··Thanks for any·
Sam
I just wanted to thank all who have contributed answers to my question and to encourage others to continue putting in their opinions and suggestions. I am still all ears on this issue.
thanks in continuum,
Mark
Using an el cheapo Radio Shack soldering iron is possible, but the suggestion to use a 15 watt (instead of the 25 watt) iron made a HUGE difference for soldering ICs!
Using a pot scrubber made of copper (the kind you can get in the grocery store for a dollar) works MUCH better than a damp sponge for cleaning off the soldering tip. WOW!
Getting a new soldering tip once the old one looks oxidized also made a world of difference.
I know these don't sound terribly profound, but thanks to these types of "small" concepts, I was able to get my high speed circuits working on a ground plane protoboard, so my ulcers can now begin to heal.
You people are great! Thanks for your time!
Mark
