HB-25 motor controller object
Hello:
Tryed running the hb-25 motor controller object on·a prop proto bd, motors wont turn.
No pulses on any pin.
Which pin is the output on this program?
Do I have to change the·pub config statement.
I am using 2 controllers with 2 motors, 8vdc power in.
The grn leds are on and fans on controllers are running.
I have used these controllers with·a basic stamp·demo bd.
Any ideas?
·Thanks······
Any ideas?
·Thanks······
Can you post the code or provide a link to the code that you were running?
Beau Schwabe
IC Layout Engineer
I downloaded the code from the prop object exchange, under the motor heading. Thanks.
Parallax Forums - If you're ready to learn, we're ready to help.
The program is set for pin 1, dual mode, auto refresh. I think I have attached· the·motor controller object. Thanks
