HB-25 motor controller object — Parallax Forums
pebladespeblades Posts: 14
edited 2008-11-05 10:38 in Propeller 1
Hello:
Tryed running the hb-25 motor controller object on·a prop proto bd, motors wont turn.
No pulses on any pin.
Which pin is the output on this program?
Do I have to change the·pub config statement.
I am using 2 controllers with 2 motors, 8vdc power in.
The grn leds are on and fans on controllers are running.
I have used these controllers with·a basic stamp·demo bd.
Any ideas?
·Thanks······
  • Beau SchwabeBeau Schwabe Posts: 6,568
    edited 2008-11-04 19:01
    peblades,
    Can you post the code or provide a link to the code that you were running?
    Beau Schwabe
    IC Layout Engineer
  • pebladespeblades Posts: 14
    edited 2008-11-04 20:04
    Hello,
    I downloaded the code from the prop object exchange, under the motor heading. Thanks.
  • CJCJ Posts: 470
    edited 2008-11-04 20:57
    you have to set the state argument when you config() for either cog refresh or manual refresh, as well as the pin and single/dual mode to get anything out of it
    Parallax Forums - If you're ready to learn, we're ready to help.
    hello,
    The program is set for pin 1, dual mode, auto refresh. I think I have attached· the·motor controller object. Thanks
