Chips Getting Hot
Question: how hot is the PSC supposed to get when powered by USB?
I think I may have fried my chip. The situation is as follows: when I hook up the USB PSC to the cable (USB) it heats up to about 160 degrees F in about 10 seconds. At first, I thought it was because I had shorted it. But no, when I removed it from the housing and dangled it by the cable: same thing. My concern is that I had shorted it before: what happens when the five contacts (3 for the switch, two for the terminal block) are electrically connected?
I tried running the software, but it doesn't seem to control a servo. I see the FTDI usb LED flash when I change a command on the PC, so I'm assuming that I get the data correctly.
Post Edited (SRLM) : 11/4/2008 5:57:08 PM GMT
Chris Savage
Parallax Engineering
Chris Savage
On my PPDB board, I hooked up a stepper motor to the L293 chip. Input voltage is 9 V 1 A. A similar thing happened: when I ran the code from the N&V column, "Stepping out with Spin", the chip gets very hot. In about four repetitions of the program, the temperature had risen to 160F. It's very consistent, a steady rate of about 2 degrees per second. I was afraid to let it go any higher. Is it that I'm drawing too much current? I'm taking it in later today to measure and see how much I use, but if it's not that, then what?
Chris Savage
I tried it with a higher voltage (15 v) and a set maximum current draw of 600 mA (as specified by the L293D datasheet). However, when I turned it on, the voltage would pop down to about 5v, with current limited at 600 mA.
I also tried it with a physically smaller stepper, but it seemed to have the same draw.
Chris Savage
