Where can I slice Vss on the Protoboard?
Oldbitcollector (Jeff)
I'm doing another custom Protoboard and need the perfboard space on the right side.
I'm dangerously close to the Vss line that goes down the right side. I'm not using it.
Is there a place where I can knife-slice this line safely to disconnect it?
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
OBC
OBC
Look at the Protoboard with a bright light behind it.
Thanks Mike!
OBC
