ADC — Parallax Forums
ADC
PromagicPromagic Posts: 17
edited 2008-11-03 03:38 in BASIC Stamp
I am trying to read the 0-5v reading from a Sound sensor·I bought. I have a AD7705 ADC from Analog Devices. My problem is that·I don't understand what pins·go where.
I realise VSS is power and GND is ground, but which one do I plug in the input and which one does·the output come from?
http://www.analog.com/en/analog-to-digital-converters/ad-converters/ad7705/products/product.html· - Page
http://www.analog.com/static/imported-files/data_sheets/AD7705_7706.pdf·· - Data Sheet
Many Thanks!
  • $WMc%$WMc% Posts: 1,884
    edited 2008-11-02 17:51
    promagic
    I looked at the " ADC.jpg " Image You Attach. The "scan0001.jpg" Image download keeps hanging up part way in the download, so I couldn't see what was in the D.L. But I might be of some help w/ the pin use... ? does Your code use SHIFTIN/SHIFTOUT???. or some other COM. method????...maybe I2C????
    _______________________________________________$WMc%__________________in________________
    Post Edited ($WMc%) : 11/2/2008 7:48:26 PM GMT
  • MSDTechMSDTech Posts: 342
    edited 2008-11-03 00:41
    The AD7705 is probably a much more complex chip than you need for this application. Since the sound detector has a 0-5v output you shouldn't need to use the·opamp built into the AD7705. I suspect an ADC0831 or the LTC1298 would be more appropriate and simpler to use, specifically you need a resonator attached to the AD7705. The setup on the AD7705 alone uses more programming than the others.
    Typical setup for a AD7705:
    AD7705 Constants
    WriteCLK CON %00100000 'Next operation a write to the Clock Register
    ReadClk CON %00101000 'Next operation a read from the Clock Register
    ClockSET CON %00001100 'Clock Register Datasheet P19
    WriteSTP CON %00010000 'Next operation a write to the Setup Register
    ReadSTP CON %00011000 'Next operation a read from the Setup Register
    SetupSET CON %01111010 'Setup Register Datasheet P17
    WriteDRDY CON %00001000 'Read Communications Register to determine status DRDY bit
    WriteDATA CON %00111000 'Next Operation a Read from the DATA Register.
    ZeroCal CON %10110010 'Zero Calibration
    SerReset CON %11111111 'Value for Serial Interface reset
    'Initialize the Rain/Snow Gage ADC
    '1. WRITE TO COMMUNICATIONS REGISTER SELECTING CHANNEL & SETTING
    ' UP NEXT OPERATION TO BE A WRITE TO THE CLOCK REGISTER (20 HEX)
    SHIFTOUT RS_Din,RS_CLK,MSBFIRST,[noparse][[/noparse]WriteCLK]
    '2. WRITE TO CLOCK REGISTER SETTING THE CLOCK BITS IN ACCORDANCE
    ' WITH THE APPLIED MASTER CLOCK SIGNAL AND SELECT UPDATE RATE FOR
    ' SELECTED CHANNEL (0C HEX)
    SHIFTOUT RS_Din,RS_CLK,MSBFIRST,[noparse][[/noparse]ClockSET]
    PAUSE 200
    SHIFTOUT RS_Din,RS_CLK,MSBFIRST,[noparse][[/noparse]READCLK]
    SHIFTIN RS_Dout,RS_CLK,MSBPOST,[noparse][[/noparse]rs_config]
    '3. WRITE TO COMMUNICATIONS REGISTER SELECTING CHANNEL &
    ' SETTING UP NEXT OPERATION TO BE A WRITE TO THE SETUP REGISTER (10 HEX)
    SHIFTOUT RS_Din,RS_CLK,MSBFIRST,[noparse][[/noparse]WriteSTP]
    PAUSE 200
    '4. WRITE TO SETUP REGISTER CLEARING F SYNC, SETTING UP GAIN,
    ' OPERATING CONDITIONS & INITIATING A SELF-CALIBRATION
    ' ON SELECTED CHANNEL (40 HEX)
    SHIFTOUT RS_Din,RS_CLK,MSBFIRST,[noparse][[/noparse]SetupSET]
    PAUSE 200
    GOSUB WaitForADC
    RETURN
  • PromagicPromagic Posts: 17
    So I'm using a bazooka to kill a fly huh?
    Wow the ADC0831 and the LTC1298 is MUCH simpler!
    Thank you very much!!
