Brushless motor control
Can the BASIC stamp by itself control a typical brushless or do I need some other component in order to control it? Also anyone know a good link on how I would control it with the microcontroller (with or without this extra component). Thanks
From any microcontroller, you connect either PWM or voltage for speed set, if you don't need to vary the speed, you only need to turn the motor on of off and set the direction. Outputs then are PWM/DAC, Run/Stop, Direction.
Chris Savage
Parallax Engineering
Chris Savage
Chris Savage
Chris Savage
It sounds like You have a " TOP SECRET " project from the CIA./US G. And I don't want You to compromise Your mission. But a lil. more info on the app. would be helpful. like load,RPM,speed range, etc. This will not leak any info on Your mission if You word it rite.....as it can be appled to anything...........What is the Load?...What is the RPM's?... Does it need to vary?...What's the voltage?...
______________________$WMc%_______________________________Kfabeit___________
it's a L6232b motor driver
