Basic Stamp + Reed Relay IC + 12V DC Motor
I'm planning to use a reed relay IC as a switch to control the on/off of the 12V DC through BasicStamp2. Attached is the datasheet of the reed relay IC (RS291-9710) and a diagram of components in mind. My two questions are:
1. How do I connect the motor and BasicStamp2 to the reed relay IC?
2. How do I use the reed relay IC?
process.· As the magnetic field in the reed relay's coil·collapses the counter EMF might spike the BS2.
It's always best to interface the output either with a SSR (solid state relay that can be driven directly off the BS2 --- even up to 120 vac.·
Or, perhaps use a 2N2222A buffer transistor which will operate fine on 12 VDC and can run a 12 VDC reed relay.· A reverse diode is usually placed directly
across the relay coil to sap the collapsing field transient.
Dr. Resonance
Post Edit -- in the attached schematic, the coil turns on when the output is "0".· The coil resistance is "500Ω", so the draw is 10mA.· "+5" is "Vcc".
Post Edited (PJ Allen) : 10/28/2008 2:07:23 AM GMT
