More eagle help
How do i place a off page connection in eagle cad software. For example I want pin 3 on the propeller to go to some other place in the schematic but I don't want to run a wire all over the place, I want to just add a label or some off page mark.
Thnaks
Thnaks
Hmm is it add "wire" or add "net" ? So long ago now....
Use the 'Label' tool (the one with the ABC above the wire) to put a label the net. Doing this reduces confusion, and makes your schematic a little cleaner.
Also remember that you can type all these commands in the command textbox instead of trying to find the tool button. Type 'name' to set the name of an object and type 'label' to set the label.
When using labels, you must go back through your design to make sure they are really connected to the part, it is easy to do this by double clicking on the part to see if the wire lights up indicating it is connected.
You can use labels for power, gnd, vss, vdd etc if you want too.
Another thing is, if you are are using multiple instances of the same net running to different parts, and you happen to come back later and delete a part, there are cases where you may accidentally un-name other nets by the same name, so always pay close attention to net names when deleting labels.
