PID returns integer?
So I keep looking at this code from obex, for a pid loop.
In the comments it says returns an integer. But in my mind it would seem to return a float number. Am I missing something, is it using a different version of floatmath than I have? Along with this doesnt setpoint and position need to be floats in order for the code to work correctly?
I hope it is not inappropiate to post the whole code like this, if so please remove it or tell me and I will.
Thanks for the time.
TJ
Post Edited (TJHJ) : 10/24/2008 5:30:26 PM GMT
PID Controller
Code by David C. Gregory ([url=mailto:david.c.gregory@gmail.com]david.c.gregory@gmail.com[/url])
Inspiration by "PID without a PhD" by Tim Wescott, 2000
This is an elegant PID controller object. It has only two methods
set - used to set the gain characteristics of the controller
update - used to give the controller new information and get a new output
Basic controller tuning is described by Wescott, [url=http://www.embedded.com/2000/0010/0010feat3.htm]http://www.embedded.com/2000/0010/0010feat3.htm[/url]
obj
fMath : "FloatMath"
var
long pGain 'Proportional Gain
long iGain 'Integral Gain
long dGain 'Differential Gain
long iMin 'Minimum Integral Windup
long iMax 'Maximum Integral Windup
long iState 'Integral State
long dState 'Previous position, used for calculating rate of change of position
pub set(_pGain,_iGain,_dGain,_iMin,_iMax)
{{ Initiallizes PID controller. Also usefull for modifying
controller characteristics during runtime. }}
pGain := _pGain
iGain := _iGain
dGain := _dGain
iMin := _iMin
iMax := _iMax
iState := 0.00
dState := 0.00
pub update(setpoint, position) | pTerm, iTerm, dTerm, error
'' Updates the controller with new information.
'' Returns the new output setting as an integer.
error := fMath.Fsub(setpoint,position)
pTerm := fMath.Fmul(error, pGain)
iState := iMin #> (fMath.Fadd(iState,error)) <# iMax
iTerm := fMath.Fmul(iState,iGain)
dTerm := fMath.Fmul(dGain,fMath.Fsub(position,dState))
dState := position
return(fMath.Fsub(fMath.Fadd(pTerm,iTerm),dTerm))
TJ
Paul Baker
