PID returns integer?
TJHJ
So I keep looking at this code from obex, for a pid loop.
In the comments it says returns an integer. But in my mind it would seem to return a float number. Am I missing something, is it using a different version of floatmath than I have? Along with this doesnt setpoint and position need to be floats in order for the code to work correctly?
I hope it is not inappropiate to post the whole code like this, if so please remove it or tell me and I will.
Thanks for the time.
TJ
Post Edited (TJHJ) : 10/24/2008 5:30:26 PM GMT
{{ PID Controller Code by David C. Gregory ([url=mailto:david.c.gregory@gmail.com]david.c.gregory@gmail.com[/url]) Inspiration by "PID without a PhD" by Tim Wescott, 2000 This is an elegant PID controller object. It has only two methods set - used to set the gain characteristics of the controller update - used to give the controller new information and get a new output Basic controller tuning is described by Wescott, [url=http://www.embedded.com/2000/0010/0010feat3.htm]http://www.embedded.com/2000/0010/0010feat3.htm[/url] }} obj fMath : "FloatMath" var long pGain 'Proportional Gain long iGain 'Integral Gain long dGain 'Differential Gain long iMin 'Minimum Integral Windup long iMax 'Maximum Integral Windup long iState 'Integral State long dState 'Previous position, used for calculating rate of change of position pub set(_pGain,_iGain,_dGain,_iMin,_iMax) {{ Initiallizes PID controller. Also usefull for modifying controller characteristics during runtime. }} pGain := _pGain iGain := _iGain dGain := _dGain iMin := _iMin iMax := _iMax iState := 0.00 dState := 0.00 pub update(setpoint, position) | pTerm, iTerm, dTerm, error '' Updates the controller with new information. '' Returns the new output setting as an integer. error := fMath.Fsub(setpoint,position) pTerm := fMath.Fmul(error, pGain) iState := iMin #> (fMath.Fadd(iState,error)) <# iMax iTerm := fMath.Fmul(iState,iGain) dTerm := fMath.Fmul(dGain,fMath.Fsub(position,dState)) dState := position return(fMath.Fsub(fMath.Fadd(pTerm,iTerm),dTerm))
TJ
Paul Baker
