RCTIME object
Beau Schwabe wrote an RCTIME object, and I was wondering if someone could explain the the third argument of the start method.
Sorry, I'm on my mac, so I don't have the code with me, but the method signature is start[noparse][[/noparse]Pin, State, RCValueAddress].
What is the RCValueAddress? Does the object return the time measurement to an address in memory?
Thanks in advance!
-Rob Lockhart
Thanks in advance!
-Rob Lockhart
Yes, 'RCValueAddress' is the address value where you want the RCTIME result written back to.
Beau Schwabe
IC Layout Engineer
The syntax uses parentheses rather than square brackets, so you'd have object.start(15, 0, @variable)
In my object you can simply call a function and use the return value (in addition to a background mode).
I droppped my laptop and am waitig for the new one to arrive, so I can do a final test of the code. I will post here and on OBEX ...
Although I think I tested thorougly, I would love you to test this object.
-Rob
Let me know what you think.
