Problem with Servo control or Servo32v3 — Parallax Forums
GeorgeCollinsGeorgeCollins Posts: 132
edited 2008-10-16 05:36 in Propeller 1
I am using the Prop Object Servo32v3 to control servos. I using a spin studio board connected to a CrustCrawler Quadruped, which has 8 hobby servos.
If I do the following code:
CON
    _clkmode = xtal1 + pll16x
    _xinfreq = 5_000_000                                'Note Clock Speed for your setup!!
OBJ
  Servo : "Servo32v3"
PUB Main
  Servo.start
  Servo.Set(0,1000)
  Servo.Set(2,1000)
Servo 0 sets but Servo 2 doesn't
If I reverse the order
CON
OBJ
  Servo : "Servo32v3"
PUB Main
  Servo.start
  Servo.Set(2,1000)
  Servo.Set(0,1000)
Servo 2 sets but not servo 1. Both servos obviously work and are connected. Why does it matter what order I set the servos in? How do I set multiple servos at the same time?
The prop and servos have different power supplies, and I do not think current drain is the issue.
Thank you for your help.
George Collins
    edited 2008-10-16 04:27
    I believe you have to call Servo.set once for each servo's initial position prior to calling Servo.start.
    Read the comments in the source code for the included demo program.
    edited 2008-10-16 05:22
    GeorgeCollins,
    Mike is correct, The Servo's must be preset to a known position before you start the servo routine. Doing this also provides information as to what pins you will be using for servo's creating a mask so that the other pins will be ignored from within the servo routine.
    Beau Schwabe
    IC Layout Engineer
  • GeorgeCollinsGeorgeCollins Posts: 132
    Thank you, that solves it.
