Problem with Servo control or Servo32v3
I am using the Prop Object Servo32v3 to control servos. I using a spin studio board connected to a CrustCrawler Quadruped, which has 8 hobby servos.
If I do the following code:
Servo 0 sets but Servo 2 doesn't
If I reverse the order
Servo 2 sets but not servo 1. Both servos obviously work and are connected. Why does it matter what order I set the servos in? How do I set multiple servos at the same time?
The prop and servos have different power supplies, and I do not think current drain is the issue.
Thank you for your help.
George Collins
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 'Note Clock Speed for your setup!! OBJ Servo : "Servo32v3" PUB Main Servo.start Servo.Set(0,1000) Servo.Set(2,1000)
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 'Note Clock Speed for your setup!! OBJ Servo : "Servo32v3" PUB Main Servo.start Servo.Set(2,1000) Servo.Set(0,1000)
George Collins
Read the comments in the source code for the included demo program.
Mike is correct, The Servo's must be preset to a known position before you start the servo routine. Doing this also provides information as to what pins you will be using for servo's creating a mask so that the other pins will be ignored from within the servo routine.
Beau Schwabe
IC Layout Engineer
