quick question on Nuts & Volts #125 (Control from your favorite terminal)
Hello,
In N&V 125, Figure 125.1 shows SX28 connected to MAX232 chip which is then connected to PC's DB-9 COM port.
Judging by the schematics of Prof. Dev. Board, I think I can just connect my PC's COM port to the X-13 (RS232) connect on PDB.·
And I would use my PC's USB port (using USB to COM adapter) to program the SX28 on PDB.
Is my assumption correct?
Thanks.· ·
Thanks.· ·
Judging by the schematics of Prof. Dev. Board, I think I can just connect my PC's COM port to the X-13 (RS232) connector on PDB.
Accoridng to PDB schematic, pin 7 of MAX232 chip is connected to PIN 8 of DB9-F, whereas Fig 125.1 of the article has Pin 7 of MAX232 chip connected to Pin 2 of DB9-F connector.
So, if I just connect X-13 connector to my PC, will it really work?
Thanks.
Connect X-13.RX to your SX chip
The schematic from that article is not from the PDB -- you are (yet again) making things more difficult than they actually are....
One minor thing I noticed is that when I type a command (such as "v"), I don't see "V" appear on my hyperterminal. I see that it took it because it displays as expected on hyperterminal.
Is there some setting that I need to do so that I can see what I am typing on hyperterminal?
Thanks.
