quick question on Nuts & Volts #125 (Control from your favorite terminal) — Parallax Forums
basicstampedebasicstampede Posts: 214
edited 2008-10-11 21:15 in General Discussion
Hello,
In N&V 125, Figure 125.1 shows SX28 connected to MAX232 chip which is then connected to PC's DB-9 COM port.
Judging by the schematics of Prof. Dev. Board, I think I can just connect my PC's COM port to the X-13 (RS232) connect on PDB.·
And I would use my PC's USB port (using USB to COM adapter) to program the SX28 on PDB.
Is my assumption correct?
Thanks.· ·
  • basicstampedebasicstampede Posts: 214
    edited 2008-10-10 16:30
    excuse my typo. I meant to write above:
    Judging by the schematics of Prof. Dev. Board, I think I can just connect my PC's COM port to the X-13 (RS232) connector on PDB.
  • JonnyMacJonnyMac Posts: 9,809
    edited 2008-10-10 18:48
    Yes, I do it all the time. The pin on the PDB marked RX is from the PC, the pin marked TX is to the PC.
    edited 2008-10-11 18:37
    JonnyMac,
    Accoridng to PDB schematic, pin 7 of MAX232 chip is connected to PIN 8 of DB9-F, whereas Fig 125.1 of the article has Pin 7 of MAX232 chip connected to Pin 2 of DB9-F connector.
    So, if I just connect X-13 connector to my PC, will it really work?
    Thanks.
    edited 2008-10-11 20:18
    Connect the DB-9 (associated with X13) to your PC.
    Connect X-13.RX to your SX chip
    The schematic from that article is not from the PDB -- you are (yet again) making things more difficult than they actually are....
    edited 2008-10-11 20:29
    Jonny Mac, thank you! It works!
    One minor thing I noticed is that when I type a command (such as "v"), I don't see "V" appear on my hyperterminal. I see that it took it because it displays as expected on hyperterminal.
    Is there some setting that I need to do so that I can see what I am typing on hyperterminal?
    Thanks.
    edited 2008-10-11 21:09
    Hyperterminal lets you echo characters typed: Properties --> Settings (tab) --> ASCII Setup
    Excellent. This is a fascinating program. Thank you for the excellent article.
