how to quit noisey motors
Hello
I have a tamiya dual gear box from pololu the controller that comes with it. (39.99 by the way for both) to put a .1uf cap on the motors. I called tech support and they say to put one on the + to case one on - to case and one from + to - on each motor to quit them down. I was wondering is there any other way to do this. is there any other device i can connect to each motor to accomplish the same thing.
remember i am a noobie at this. just starting into electronics so just wondering .. and due to the fact i only have 3 104 ceramic caps at the moment LOL
Badger
Badger
i just wont to make sure i got this in my head they said to solder one + to motor case - to motor case and then another from + to - so that makes three for each motor. so doing such will not harm the motor or controller
sorry to repeat my self i just wanted to make sure i am understanding what i am trying to say and what the response up. I am on a very high dose of pain meds so i am double checking ok
Badger the High
i can take some 104's off an old board i have. that is what they suggested
Try and keep the motor wires as far apart from other electronics as possible especially if there is any radios e.g. RC controllers.
I have found the tamiya motors and similar motors (the RM2/3 that can be used to replace the tamiya motors) are very noisy, and you have to take extra steps with those motors that I didn't need on similar size motors.
PS, when I have used the tamiya gearboxes before, I tend to switch the motors to the RM3, then I can use a cheaper motor controller. The reduced cost of the cheaper motor controllers outways the cost of replacing the motors.
Check out towerhobbies.com brushed motors youll find some pics
Paulk
