Newbie question about TV vs. VGA display
Hi all,
Up until recently, I've been using a TV to display my data, but now its screen is getting overcrowded, so I was wondering if I can get more resolution (more lines of data, more characters, etc.) on a VGA.
And while I'm at it, I guess I should ask what constitutes a VGA.· I've got an old junker Mac, about 10 years old, with a terminal that sorta looks like a TV.· Would that be a VGA?· And is it a simple matter of blowing the dust off of it and matching its pins with the VGA object?·
many thanks,
Mark
It might be the Information Age but the Eon of Ignorance has yet to end.
many thanks,
Mark
It's nice to know I have that option, so long as I've got pins left for it. I've just got the raw DIP chip so I'll have to kluge a plug if I go that route.
many thanks,
Mark
ucontroller.com/documentation/VGADoc.html
He's also posted an instructional for converting it to breadboard use on his homepage.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
I got sidetracked by some other glitches, so it will be a while before I'm brave enough to pump time into this VGA thing. But I'll definitely need it if I want to cram all my data onto a single screen. Either that, or turn my TV into a hieroglyphic disco display, flashing the room with an ever-changing array of numbers.
cheers,
Mark
