Question about BoebotBasic
·have gotten my robot finished. I have done all the things I want individually, but not at one time.The following is a· list of the versions that I have used:
Mel.BIN···················· :· my own version did not work
ModifiedBoebotBasic··· : my modified basic - did not work
Leslie.BIN··················: again, my modified -did not work
BoebotBasicXP.BIN····· : did not work
BOEBOTBasicPP.BIN···· : worked great 9600 baud
BoebotBasic.BIN········· : did not work
BoebotBasicUS.BIN····· : worked great· 9600 baud
Fem2basicProterminal·· : worked great at 115,200 baud
DongleBasic··············· : worked ok
Now, by not working, I mean that I could not connect up to them with the PST terminal program in order to list or run my programs.
Notice that all of these are BIN files.· What I really need is BoebotBasicUS.SPIN , and BoebotBasicPP.SPIN so I can change the code and make my OWN binary file that is different.· I have written small subroutines and BS2 Functions and they work great. But, I need to be able to change the BIN file. The only way to do this is to have the .SPIN source code. I hope that someone will share this with me, because I will have to rewrite all of this. I would also like to lilst my code, but I am not finished with it yet. Most of my problems are to do with the IR only having one channel and the robot is running into things. I have made a binary file from BOEBOTBASIC.SPIN, but it does not work with my system as noted above.
If anyone wants to jump in and make suggestions, I am willing to try them.· I would also like to see a BasicStamp to Propeller Basic code compiler.· So, we could enter in the BS2 basic commands. Those are so much easier to follow and understand.· But, I guess that has been suggested before and only a few guys need this.·
Thanks for all of your help, guys.· However it turns out, you have been a lot of help and I can live with whatever comes back to me.· I am very happy with my little boebot. I just want to give him more, if possible.
Hope this helps
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
DongleBasic.spin is a stripped down version of BoeBotBasic with the BoeBot specific routines and Basic statements removed. There's also only one pre-compiled version that uses the programming port at the "console".
Feel free to modify BoeBotBasic.spin and DongleBasic.spin as you wish. You can also modify the objects they use which are all included, but make sure you understand what they do and how they work with the other objects before modifying them or you may create more work and frustration than you may want.
You guys have a nice night!
Thanks for your patience.
Mike, you are Right as Rain!
I apreciate all that you do for me.
