GPS to LCD help
I·have got BS2,·4x20LCD and a gps module. But i cant seem to make·the informations showed on the·gps on the·LCD.
I want the LCD to show·valid, sats and time date on the first screen after which a few seconds later it will show·the·latitude and longitude.
And finally it will show the altitude and the speed and will be loop back to the first screen and show everything again. Can someone help me pls?
This is what i tried to edit but nothing much changes..
Well, now that I look back that sounded sort of trite. Perhaps some more guidance should be good. Download or buy the "Basic Stamp Syntax and Reference Manual" and read through it. Not just once, either. Read through it at least three times until you can quote sections (or at least paraphrase) and understand the language. Then, when you get such a program as the one above, you can tell exactly what it does. Also good (and free for download) is "What's a Microcontroller".
- Rick
If not, then disregard the following.
Look at the documentation for the LCD:
Documentation
You'll notice that all the LCDs use the same commands (with extensions for backlight and 4x20) Read through the whole thing just to get a general understanding of the device, but printout (or bookmark) pages 8-10: these are your command reference. Then go ahead and download some of the sample code that they have listed here. This is from the Smart Sensors book, and you'll find the information in chapter one. It's written for the 2x20, but should work just fine with the 4x20.
