Serial Camera - Page 2 — Parallax Forums
Serial Camera
2»
  • ChristophChristoph Posts: 13
    edited 2008-03-01 14:00
    Hi,
    has anyone continued work on the C-328?
    With the help of Rayman's and Harrison's code examples I just started on my cam.
    But after making just one picture·it stopped syncing for good.·I was already
    suspecting some fatal event in my cam·but when connecting an oscilloscope there was
    suddenly·an output from the cam's·tx pin. The cam SYNCed and made a picture. As
    soon as the oscilloscope was detached function ceased. So I put a 22k resistor across
    the cam's tx pin and Vdd and it is now working ... most of the time. But not always.
    Has anyone got the same problem and solved this?
    Does the Eval board give any clues (I haven't got it)?
    Is it a problem of too long wires? I left the cable's length at 30cm as it was shipped.
    Does anyone know where to download the evaluation software (C328Ap.exe)? I couldn't
    find it on COMedia's web site.
    Thank You,
    Christoph
  • RaymanRayman Posts: 16,223
    edited 2008-03-01 19:54
    What baud rate are you using? I really only had luck at 115200...
    edited 2008-03-01 20:00
    Rayman said...
    I am using 115200 Baud as well.
    Christoph
  • J.PJ.P Posts: 1
    edited 2008-09-18 17:25
    Hi, im using the C328-7640 aswell but havent got it· even to respond to my sync shakehead.gif· all i get back is the same·byte array·i send to the camera 170 13 0 0 0 0.
    could anyone please supply some code help in C# if possibly?
  • Sniper KingSniper King Posts: 221
    edited 2008-09-18 21:33
    How fast can you move a 640x480 image to the SD card?
    ·- Ouch, thats not suppose to be hot!··
    Michael King
    Application Engineer
    R&D
    Check out Project: PSAV Persistent Sailing Autonomous Vehicle
