JST connectors - embarrassing question
I'm embarrassed to have to ask this, but... is a JST connector supposed to be permanent, or am I supposed to be able to unplug the thing?
Here's the kind of connector I'm using:
http://www.sparkfun.com/commerce/product_info.php?products_id=339
and yes, I'm sure the other end is the one intended for that battery's connector. When I try to pull it out, it definitely doesn't want to budge. Is there something I'm supposed to push or pull on to let it loose? I'm pulling hard enough that I'm on the verge of breaking something, and it's not coming out.
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Thanks.
