That's incredible???!!! real or not??
·ttp://www.robotshop.ca/home/products/robot-kits/robot-construction-kits/robotis-bioloid-robot-construction-kit/index.html▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
look up ,look up· to most of them,a lot of work would mean ,At the moment the liberty freedom forever freedom· and no more wrong ways......to make me worry sad sad.........
"THE ONLY TRUE WISDOM IS IN KNOWING YOU KNOW NOTHING." - SOCRATES
the foots are to be extremely functional for one equilibrium ok...
do you have consience of the fingers of the foots??
of humans ??
and the moviment of the arms have to be calculated with velocity , torso etc...
N
balance robot.
and much more..........................................0 0.................................................
it forgives me if I became to understand bad
Chris Savage
Parallax Engineering
It will be much easier to understand you if you post your comments in Portuguese.
Also, please explain: What is incredible (unbelievable ?) about the robots at :
http://www.robotshop.ca/home/products/robot-kits/robot-construction-kits/robotis-bioloid-robot-construction-kit/index.html
It appears that you do not believe those robots can balance themselves because they have no sensors or feedback mechanisms in their toes, and the robot's balance (center of gravity) will be compromised by the moments of inertia of the arms and torso·?· Or, something like that ?
PAR
