look up ,look up· to most of them,a lot of work would mean ,At the moment the liberty freedom forever freedom· and no more wrong ways......to make me worry sad sad.........
How much sensor need to equilibrium of the robot?
the foots are to be extremely functional for one equilibrium ok...
do you have consience of the fingers of the foots??
of humans ??
and the moviment of the arms have to be calculated with velocity , torso etc...
the rank forgives mine. quiz I say that in one robot asks for, the feet I am essential, for a good balance of robot. The fingers of the feet of in the human beings also they play a crucial function in the balance. the relation of center of one gravity robot asks for with arms, and criticizes, therefore the balance command must be considered as one weight that has its characteristics in meter for second and angular in relation to the center of one
balance robot.
and much more..........................................0 0.................................................
it forgives me if I became to understand bad
It appears that you do not believe those robots can balance themselves because they have no sensors or feedback mechanisms in their toes, and the robot's balance (center of gravity) will be compromised by the moments of inertia of the arms and torso·?· Or, something like that ?
"THE ONLY TRUE WISDOM IS IN KNOWING YOU KNOW NOTHING." - SOCRATES
of humans ??
N
balance robot.
Parallax Engineering
It will be much easier to understand you if you post your comments in Portuguese.
Also, please explain: What is incredible (unbelievable ?) about the robots at :
http://www.robotshop.ca/home/products/robot-kits/robot-construction-kits/robotis-bioloid-robot-construction-kit/index.html
PAR
