Reset PINK to factory settings
Tumbler
Hello,
Is it possible to reset the PINK to factory settings?
I'm using Cute ftp to write some pages to the pink
Works good, but i can't see the uploaded files in cute ftp.
I've created a folder 'img' too, but can't erased it anymore
I only can delete htm files, no folder files [noparse]:([/noparse]
In my ftp program i can only see the folders, no htm files
DGSwaner
"When in doubt, use C4" - Jamie Hyneman, Myth Buster
Gives an error,while dropping the same folder.
I also renamed the folders and tried to erase them, no succes
The only thing i can do is making new folders and rename them.
Post Edited (Tumbler) : 9/14/2008 6:52:23 PM GMT
There have been a few issues reported in this area that we are actively exploring. What we’re seeing is that in some cases certain programs behave differently and cause results that are hard to reproduce. In most cases we have been bale to remove folders created by some other program from the DOS FTP built in to Windows. In two cases we discovered programs had put sub folders into these folders that we could not delete, yet they did not show up in the programs that created them. Try using the DOS-based FTP (which is the simplest) to connect and rename/delete folders. See how that works for you.
Chris Savage
Parallax Engineering
No succes with the DOS based ftp.
Only rename the folder is alloud.
Chris Savage
