Reset PINK to factory settings — Parallax Forums
TumblerTumbler Posts: 323
edited 2008-09-16 20:49 in General Discussion
Hello,
Is it possible to reset the PINK to factory settings?
I'm using Cute ftp to write some pages to the pink
Works good, but i can't see the uploaded files in cute ftp.
  • lenswerkslenswerks Posts: 40
    edited 2008-09-14 10:45
    Did you try using your browser to ftp, then just drag and drop pages, highlight the file or directory and delete?
  • TumblerTumbler Posts: 323
    edited 2008-09-14 10:51
    when i· acces trough my webbrowser, i can see all files and folder.
    I only can delete htm files, no folder files [noparse]:([/noparse]
    In my ftp program i can only see the folders, no htm files shocked.gif and can't delete the folders too.
    edited 2008-09-14 15:15
    Just guessing, but could it be that your FTP logon / password is not the same as WEB access? I don't see where it would make any difference with the PINK, but might be worth looking at.
    edited 2008-09-14 15:25
    Try to drop a file of the same name as the directory and if that works, then try and delete the file.
  • DgswanerDgswaner Posts: 795
    edited 2008-09-14 15:36
    Rename a file or folder and then try and erase it. I use dream weaver and can only upload with it. I have to do everything else with WSftp.
    DGSwaner
    "When in doubt, use C4" - Jamie Hyneman, Myth Buster
    edited 2008-09-14 18:47
    @ lenswerks
    Just guessing, but could it be that your FTP logon / password is not the same as WEB access? said...
    Yes, logon and password are the same.
    Try to drop a file of the same name as the directory and if that works, then try and delete the file said...
    Gives an error,while dropping the same folder.
    The only thing i can do is making new folders and rename them.
    Post Edited (Tumbler) : 9/14/2008 6:52:23 PM GMT
    edited 2008-09-15 19:26
    Tumbler,
    There have been a few issues reported in this area that we are actively exploring. What we’re seeing is that in some cases certain programs behave differently and cause results that are hard to reproduce. In most cases we have been bale to remove folders created by some other program from the DOS FTP built in to Windows. In two cases we discovered programs had put sub folders into these folders that we could not delete, yet they did not show up in the programs that created them. Try using the DOS-based FTP (which is the simplest) to connect and rename/delete folders. See how that works for you.
    Parallax Engineering
    edited 2008-09-16 12:56
    Chris,
    No succes with the DOS based ftp.
    Only rename the folder is alloud.
    We’re running some tests today. After we’ve determined what is going on I will post a reply back here again.
