Better Data comparison perhaps? — Parallax Forums
edited 2008-09-14 12:33 in Propeller 1
I've become a bit stumped over a simple data comparison I'm working on for a passcode demo.
Code looks something like this...
relevant portion shown..
 repeat
    if key == 16384
      text.str(string("A"))
      code := code + "A"
    if key == 32768
      text.str(string("B"))
      code := code + "B"
    if code == combination
      outa[noparse][[/noparse]8]:=0  '' Turn off P8 showing deactivaed.
    waitcnt(12_000_000 + cnt)
DAT
combination  byte  "BA",0
For some reason my comparison sees the B entered first and thinks it's a complete match.
What am I not seeing?
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
  • TimmooreTimmoore Posts: 1,031
    edited 2008-09-13 21:13
    I think combination is defined as a byte so accessed as a byte so doesn't look at A, dont you want
    code == word[noparse][[/noparse]@combination]
    edited 2008-09-13 21:20
    Duh! Thanks.. Just had to switch my brain back on..
    Solved it mathematically instead, but I see the error of my original method.
    Thanks!
    OBC
  • WhitWhit Posts: 4,192
    Good job Timmoore!
    As one of my college profs used to say, "Unfortunately computers do exacly what you tell them to do." wink.gif
    OBC, Glad you got it firgured out.
    Whit+
