Ferrite Bead Specs for FT232RL ??? — Parallax Forums
Sens-a-DatSens-a-Dat Posts: 44
edited 2008-09-13 15:16 in General Discussion
Can anyone recommend what specs should be used for the ferrite bead with the FT232RL chip? I am reviewing the FTDI document for this chip and there is a recommendation to use a ferrite bead between pin 1 of the USB socket and the VCC of the FT232RL chip.
I do not have any knowledge in this area and would appreciate any help one may have.
Thank you,
Gary
    I·think that·"whatever" will work.· Get a bead, pass a wire through, you got it.· If it was critical then they'd specify.·
    [noparse][[/noparse] Somebody object. ]
