Tempest clone, bugs and inexperience
Remember Tempest?
I am having a few problems with my graphics routines and could use some pointers.
Drawing the playfield:
Basically I have declared a list of bytes in DAT which define the front 'face' of the level.
The rear pseudo perspectivised points are calculated with a scale and offset and then lines are draw from front to back points.
This works OK for now.
Drawing the tempest:
Originally while drawing the playfield I checked the tempest position (updated from another method) and changed the line color to indicate which segment the player was on.
I figured it would be better to move this to another method (draw_tempest).
This method attempts to draw the two lines which the tempest is on in a different color (overwriting what draw_playfield drew)
Drawing of the tempest itself should go in here next.
I seem to be misguided in my way of 'indexing' into the level table.
I know this must have to do with HUB ram being Byte addressed, but I cannot figure it out completely.
Help would be appreciated greatly.
Attached is the code, draw_playfield and draw_tempest are where I am having problems. I have heavily commented where I am stuck.
I only have a protoboard but figured this would be a more appropriate place to post, should get my hydra book tomorrow [noparse]:)[/noparse]
Jesse
W5JCD
Jesse
W5JCD
It's quiet around here at the moment. Don't know if you've got this one fixed yet. I don't have a working PC at the moment so I can't run your code, but it looks like you still have code in both draw_playfield AND draw_tempest to draw the different colored lines. I suggest you pick one or the other, andthen see if your problem goes away. If not, you'll at least have narrowed the problem down.
Cheers,
Steve.
Help to build the Propeller wiki - propeller.wikispaces.com
Play Defender - Propeller version of the classic game
Prop Room Robotics - my web store for Roomba spare parts in the UK
I believe I have figured this out, got my hydra book [noparse]:)[/noparse] awesome (except the cover came off already, no biggie, content is the value)
My main problem was how I was indexing into the level vertex list. It took me 5 minutes to fix it after reading that one page in Andre's book.
Tomorrow I will try to polish off the drawing methods. Though now, I'm not sure I am going about it the right way, I may have to start from scratch after reading
about how to organize a game. This is my first try at a game since the obligatory text based "choose your own adventure" in GW Basic years ago.
p.s. I think I am mistaken in naming, Tempest is the game, I hear references to "The Claw" as the player's character, and "The Web" as the playfield. Am I right or Wrong? (to quote skynyrd)
Jesse
W5JCD
Post Edited (Jesse Druehl) : 9/9/2008 3:26:51 AM GMT
