sound
I found a music playback module that used two inputs to play and scroll through recordings. It played recorded sounds loaded via a usb connection. The company that sold it seems to have gone out of business and I did not receive my order. I need to get something asap to use with a basic stamp. I have maybe 3 outputs left to control it and I will have wave sounds looping and a voice recording playing at the end of the cycle. I have found others but need a bit of cicuitry to be built and I am on a time frame. can any one help.
take a look at it here.
http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/Level/a/ProductID/423/Default.aspx?SortField=ProductName,ProductName
in all seriousness. The Propeller is totally over kill for this but it could easily do what you need. I doubt you can find a product for under $20.00 that can do this and it would be pretty easy to do.
DGSwaner
"When in doubt, use C4" - Jamie Hyneman, Myth Buster
