SD and mini-SD WiFi cards
Cluso99
Just found SD and mini-SD WiFi cards on ebay. Presume they will require operating stacks on the Prop so not sure if they are useful.
Thought I would just post the info anyway. Would be a neat solution though, especially since a number of you are interfacing SD cards.
One problem you will have is the 802.11 specs are not easily available. You either need to buy them from the IEEE or attend the IEEE meeting. Understaning the card interface without understanding the 802.11 MAC/PHY specs would be not easy
Post Edited (Timmoore) : 9/6/2008 12:48:50 AM GMT
At the very least, it would eliminate a lot of the hardware needed to network the prop!
http://www.cardaccess-inc.com/products/index.php?a=wlan_burt_buy
