Write to file on computer
I know the prop can read from a file that is in the same directory as the executing spin file, but can it create, and append to a file? I want to stream GPS data wirelessly to another prop and just have that data recorded with out the need for an SD card. Thaks
Hunger hurts, starvation works!
HTH.
Cheers,
Simon
www.norfolkhelicopterclub.com
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again
BTW: I type as I'm thinking, so please don't take any offence at my writing style
Hyperterm - Be careful if you use the standard Prop serial (USB) port as Hyperterminal asserts DTR which resets the prop. Provided you disable the DTR in hardware, Hyperterminal does a great job at capturing text. While it is missing in Vista, you can copy the files to Vista to make it work (I did) - Google this for more info.
It should also be possible to write a mini VBA application in Excel to capture straight into Excel.
