What are the possible sources of interrupts for SX28?
Hello.· I am learning about INT.· What are the possible sources of interrupt?·
Can anyone point the way to codes showing how the possible sources of interrupt is used in real code?
So far, I've seen·code to use the RTCC internal clock to call INT.
But I have not seen code on INT based on RB pin change.·
http://forums.parallax.com/showthread.php?p=741829
regards peter
So the only sources of INT are: 1. RTCC and 2. RB? No other sources of INT?
Regarding RB, can I choose to trigger INT when say a) on rising edge of RB.0 b) falling edge of RB.0 c) when RB.0 is high d) RB.0 is low. All 4 of these are possible?
There is also the RTCC input pin that can trigger an interrupt.
regards peter
